Empire-CAT Machinery Tech
a while back i replaced my axle with a new one, i didnt leak even with the old one... so a few months later it takes adump on me, starts leaking fluid on the left side trans seal, so today i put in a new axle seal, thinking i might of fugged up my old one... well anyways me and my buddy replaced it and is still leaking fluid, i think its the damn autozone new axle that is not machined to specs..
its a new beck arnley seal.... what do u guys think, bad axle??
and also is leaking from the right side lower sensor what sensor is it? it has a green rubber around it, and below the right side input shaft?
this shizz is pizzn' me of :mad:
The Genesis
that sensor is the fifth gear position sensor(if its the one im thinking ur describing)
As with the seal, you can take the spring inside it, cut it a little bit and put it back in to create a tighter seal.
employment whiplash, NC
Check those sensors. I've replaced both of mine (neutral and reverse). There is no such thing as a 5th gear sensor, BTW.
