I just bought a set of Pacesetter headers and it only came with a manifold/block gasket. The one for the cat was easy enough to find but the one from the downpipe to the manifold doesn't seem to exist. I did not receive one in the box and the coupling is two flat surfaces, not like the OEM w/ crush rings. Does it require a gasket?
Thanx, but just to double check, I called Pacestter and they said yes it does. They are going to overnight them.
El Chingon
Really, the G4 HS has a gasket. Every other header I've used has required a gasket also. Hmmm, you got a "Special" header Jordan
J/K That's weird bud.
David
'98 Super Black SE w/stuff
