Under my car getting it ready for the next event and I noticed the bolt for the front motor mount that connects to the cross member is gone.
Any one with FAST able to tell me the part number, or know the bolt size?
Apparently I need to use some loctite, because I also noticed that one of the bolts retaining the front sway bar had backed itself out about 1/4". Needless to saw I will spent a little more time inspecting before Limerock.
Thanks,
Jeffrey
wants to go play
01125-01971
SR20DE stock G20 p10 highport
Which is longer the FRONT pair of cross member bolts or the REAR cross member bolts? (The ones that secure it to the radiator support up front , and to the subframe in the rear)
UPDATE: A fellow let me know that on the p10 the REAR cross member bolts are a little longer than the front ones. It makes sense. The weight of the engine goes back when you accelerate, so those bolts need to have more threads.
