Parting out: '92 Red B13 (Not Aztec)
1974 Views 62 Replies 28 Participants Last post by  MattSfeir
Parting out: '92 Red B13 in Midcoast Maine
Edited for clarity, and because that other post for
the '93 just said it so much better than I did:
Car: '92 Sentra SE-R, red, 18?k
Here's an updated list of what I have left with prices.
This list is 99% accurate. These prices do not include
shipping. Small pieces will be sent USPS, larger ones
probably FedEx ground, or pickup.
My paypal payment address is [email protected].
Email, PM, or post with questions or shipping costs.
Photos available on serious request.
ENGINE RELATED
AC compressor - $50
airbox - $30
alternator $50 - sold
cams (pair)(high port intake cam, same as '91)$50
catalytic converter $50
cruise control assembly $25
distributor $25
ECU $50
electric fans $35
exhaust manifold w/ heatshield and DP (2 available.) $30
exhaust - gone
flywheel $40
fuel pump $20
fuel rail - $offer
fuel tank $FREE - must pick-up
intake manifold plenum (lower portion of manifold) $20
intake manifold (upper) - $offer
intake rubber (throttlebody to MAF) $10
thermostat $20
MAF sensor (2) $40 shipped
motor/tranny mounts (set) - $offer
oil pan $20 - on motor still
power steering pump $40
starter $40
steering rack $60*
throttlebody $offer
valve cover $25 on motor still
water pump $25
wiring harness $100 - still on car.
DRIVELINE
axles (pair) $95
hub - driver $40
hub - passenger $40
spindles (rear)
shift linkage $25
shifter $15
transmission $400
wheels & tires - $offer
BRAKES
calipers, rotors, mounting brackets except driver's rear caliper $offer.
SUSPENSION
control arms (front pair) $50
strut assemblies with springs (rear) $40
spring - driver front $10
spring - passenger - $10
swaybar - front $10*
sway bar - rear $10*
BODY
doors (pair) $80**
bumper cover front lower portion damaged $20
bumper cover rear $45**
carpet $10 must be cleaned
fender - passenger $40**
fender - driver $40
gas door with gas gap $15
fog lights with switch - sold
glass (all) $offer
grille - $10
headlights - $60 for pair
hood $60**
hood prop with clip $5
mirror - driver - sold
mirror - passenger - $20
mirror - rearview - $15
taillight passenger $25
taillight driver $25
spoiler $40 - sold
trunklid, without spoiler, with lights, no lock $75**
turn signals (pair) $25
wiper arms (pair) $10
wiper motor $10
INTERIOR
A-pilar panels (pair) $10
blower motor $15
blower motor resistor - sold
brake pedal assembly $20
carpet (black) $15 -
center console $20*
center vents - $10
clutch pedal assembly $20
dash $70 shipped
gauge cluster $50
headliner $25**
heater controller - $25
heater core $10
panels rear pair (lower) $35
panels rear pair (upper) $35
radio surround plastic - $20
rear deck with speaker covers $40 shipped
seats (front pair) $100**
speaker covers (rear) $10
steering wheel $65
steering wheel surround panels $10
sunroof assembly motor $40
sun visor (driver) $15 sold
sun visor - passenger - $15 shipped
sunvisor clip - 1 sold, 1 available, $5 shipped
weather stripping (around doors) $15 sold
wiring harness - interior $40
In addition, there's a complete engine available,
SR20DE, maybe swapped, maybe not - engine runs
strong, no knocks, and compression seems good.
I'm sure there is stuff not listed, please ask.
Also, all relays, switches, wiper mechanism, you
name it, it's available. Interior harness is complete
except the 2-wire fuel pump connector, which can
be gleaned for pennies at a salvage yard.
See less See more
1 - 20 of 63 Posts
How much are you asking for the hood?
Sent PM.
Peter said:
It's a '92 with around 180k? Compression's good, motor
has no knock. Not enthusiast owned, ricer owned, and
junked. Never raced, or anything fun like that.
Have all lights intact, have the hood resanded, primed,
sanded with 600, and basically ready for paint.
Bought as parts car about a year ago, need cash
for other things. Parting out everything except:
Fuel pump and sending unit.
Rear seats.
Sunroof is intact, but would the need rubber gasket resealed.
Other than that, the field is open. Head and motor
have no noises, clutch is gone, rest of it would be
great for someone with a GA project, or if they wanted
a motor to have as a functional high-port spare.
It's begging for someone to push the limits of NOS with!
If it can be unbolted, it's available. Have wheels
with Yoko ES100's about 80% tread, 1 plugged and
maybe leaking, probably easy to fix for less than $5.
There is rust on various parts, and through the unibody.
How much for the headlights shipped to 94509
Not exactly sure on shipping, have to box,
weigh, and check.
PM with reasonable offer on headlights?
Check PM's..
you have the headlights and is it a b13 let me know
PM sent.
PM sent about headlights.
Still waiting to hear back from original CA requestor.
Will give no more than 3 days to hear back.
Working IAC, FICD assembly? I can't cure my idle/timing problem w/o a set that is working... not that the cars runs poorly, by any means.
Air box and tubing to the PAIR? My tube into the airbox has broken off... glued back together w/plastic weld:).
Shipping to 33635... where it's warm all year long;).
Later,
Mark
I have a weird request. I need the plastic piece that the seat belt goes through on the door. The one on top of the door panel. Also the clips that hold it in.
I need the shift boot and the plastic piece its mounted to.
And the drivers side mirror.
Shoot me back some prices.
Peter--
The hood is very interesting, as far as the '92 SE-R for the GRM Challenge is concerned. PM me with details and the price you'd like. Shipping concerns me a lot.
Also...does the sunroof have the plastic outer trim piece that goes around the glass, up top? If so, interested in that, too.
Thanks.
PM's sent, check your PM's.
Sunroof/Hood.
SERprise In WV said:
Peter--
Thanks.
Shipping's a real hard thing on hoods. Even for
superlight ones. I'm still not going to have that
worked out until I have a prototype together.
The sunroof outer trim piece up on top actually
isn't plastic, it's fiberglass. And that's why I
swapped over the sunroof, so that's not intact.
All the interior stuff is intact, if someone had
smashed sunroof glass, this one is factory tinted,
and in perfect shape, but the rubber and plastic
trim should be removed/replaced from old one.
Fiberglass *sucks*, also, The rear 2/5th's of the
fiberglass outer trim piece first cracked, then flew
off somewhere, no idea where. The front 3/5th's
is still on it, but the scale needs to be brushed off,
the rubber resealed, and the top trim piece sealed
in with the rubber.
Peter
See less See more
how much for the suspension setup? whats the mileage on it?
PM's sent.
would you be willing to take the entire brake system off? including hubs, rear lines, and ebrake lines? if so, pm me and let me know a price. where in ME are you located? i might be able to save us both some hassle and come get it....lmk. thanks.
I *might* be able to. It's kind of difficult, but I
*probably* can. I *might* need the rear right
ebrake cable myself.
PM me, we can talk about it. I also have already given
up the driver's side rear caliper. The one that's on the
car has a very rusty caliper pin hole - it was 'engineered'
with a threaded rod, and no grease.
Hey, Peter. Sent you 2 emails w/pics via the mailing list... probably still downloading;).
Let me know how else I can help:
[email protected]
Peace out,
Mark
Pics
[email protected]
Peace out,
Mark
Need pics that give me a better idea of the location :)
If I need to rip a bunch of stuff apart, it's going
to take a little while.
Peter
Hahahahaha... seriously, you will need to "move" some things, but not have to rip anything out.
Stand next to the passenger side front bumper, facing the engine. Look down into the bay at the oil filter, then look left towards the firewall. You'll see the idle screw, which sits on top of the IAC. Look a little further down, and you'll see the FICD, it juts out perpendicular to the IAC, it's the bronze hexagonal cylinder.
The reason you'll have to move stuff is because your hands won't be able to squeeze in there to get the 4 bolts holding everything on. As it is, you'll end up doing the bottom left bolt blind... can't be seen from above. Be careful removing the FICD. It has a spring loaded piston that will shoot out, piston and spring, if it's not removed gently... ask me how I know:(.
I've removed the assembly twice. The first time was the hardest because I had know idea if I was going to be able to get my hand in there.
I'll look for the se-r.net link later, if you still want some info.
Take your time, my car's still driveable... I just want it to be tunable;).
Peace out,
Mark
See less See more
1 - 20 of 63 Posts
