Red Emblem
Old pic, but I use the same bracket still:
Nissan freak !!!
What is the piece that you used for the bracket?
That the OEM bracket. On the GTI-R, this brakcet is holding with 2 bolts on the valve cover.
If you put a SR20DE cover, you need a custom bracket to hold the cable in place.
Good luck,
Martin
you could reshape a piece of steel with a hammer and drill the holes to requirement
Red Emblem
That’s a piece of aluminum taped for the two holes on the VC and notched for the throttle cable. It came in like 3 foot length from home depot for $4 I want to say; and I just used a dermal and drill to cut, shape, and form. Good luck!
the dermal is to easy use the hammer lol
