1 - 12 of 12 Posts
Hello All,
What are the advantages and/or disadvantages of using forged Gti-r (stock DET size) pistons as opposed to using forged 87mm (300zxTT size) pistons? Which would be best to use for 350-400 reliable hp? How about turbo lag?
I tried looking for an answer in the archives, but got more confused.
Anyone know the compression ratio of either size pistons in a DE block?
I would greatly appreciate any feedback. Thanks
The 86mm forged gti-r pistons are "stock bore" good if the cylinder bore are with in spec. If there not then going with the 87mm would be the way to go by boring/honing properly with tirque plate 1mm over. Correct me if im wrong but a bigger piston/bore would give a larger area for combustion to take place?
Lawrence
92 se-r turbo
jwt 87mm block w/squirters
sitting in the garage
Fmax Stg II B13
Keep in mind the compression ratio of VG30DETT pistons that are not dished will be 9:1, GTi-R pistons will be.. 8.3:1 ? I went with VG30's due to the low cost.
Actually, GTi-R pistons in a DE will give 8.5:1 CR. The GTi-R and the BB DET use the same pistons.... the GTi-R has a lower CR because it has a bigger combustion chamber (different head)
Please forgive my ignorance, but what exactly does boring the cyliners 1mm over accomplish? If both 87mm pistons and Gti-r (or BB) pistons net 8.5:1 CR in a DE, which has the advantage? How does that 1mm over-bore benefit a turbo engine if it has the same CR as a stock (86mm) piston? Thanks
Pistons
GTiR Pistons are Cast.....NOT Forged!
GTiR Pistons and Bluebird Pistons are exactly the same!
GTiR Pistons net 8.3:1 CR in a GTiR
GTiR Pistons net 8.5:1 CR in a BB DET or DE.
Factory Cast DE and DET pistons are 86mm
JWT/ARIAS pistons are 87mm which requires a .040" (1mm) over bore of the cylinder wall.
A 1mm over bore *REQUIRES* the use of a torque plate. A torque plate simulates a torqued head onto the block. The shape of the cylinder walls change when the ead is torqued onto the block, thus creating the need to use a torque plate to plateau hone the cylinders evenly.
Over boring the motor gives you more displacement as well.
More displacement =More power!!!!!
Jah Rastafari
Your motor is just a air pump bigger pistons move more air which inturn when added with fuel makes more HP.
TurboJesus said:
If i do go 87mm pistion were do i get the torque plate ?
Richie
Have JWT do it. They have a torque plate, and have probably bored more SR20's than anyone else in the country.
yes stock pistons are indeed 86mm
92 se-r turbo
90 talon tsi awd
Lawrence
1 - 12 of 12 Posts
