1 - 8 of 8 Posts
I purchased a G20 with a Bluebird motor in it. The car is running a stock G20 ecu so I need to get a BB ecu, but I dont know whether it's a U12 or 13. How can I ID this engine? What are the differences between the two ECU programs? If its just the MAF I have an MAF with these numbers 22680/53J00/AFH50-06/3203(The /'s represent a new line). Also what are the numbers on the two ECU's. Thanks guys.
Wait a minute??? You contradicted yourself in that statment. So a U13 had a front or side mount, and if it has the piping running up in font of the engine it's a U12 is that what you meant??
91 SER Richmond, VA
If it points up its u12, down its a u13.
-Mike
You need a U12 ECU to correctly match that MAF sensor. (53J) You will also need to convert to the DET TPS and DET coolant sensors when using the DET ECU.
dont meen to jack ur thread but if im running BB throttle bodies and a t28 turbo with 444 injectors what ecu would u suggest? :confused:
1 - 8 of 8 Posts
