1 - 20 of 64 Posts
NX Lightweight Not SE-R
The goal here is to make full use of our parts bin cars this so everyone can build that Frankenstein's monster car, or at least so they know how! This is for all the junkyard dogs, the guys swapping B13s suspensions into B12s, also for all of you who can't figure out if you DET pickup tube will fit on a DE.
If we get some posts going here this might be the start of a new section. We need everyone that knows or has a part that that will swap onto another car, or into a different motor needs to post here!
10/19 Please keep unnecessary posts to a minimum from here on out. If you have a question about a certain part fitting please PM the originator of the fact, or PM me and I will try to help.
slave to the grind
300z radiator cap.......fits......b13 radiator
nx front rotors with calipers....fits.....b13
nx jdm rotors with maxima calipers(year)...fits b13
nx dashcover....fits.....b13
nx1600 digital...fits .....b13
stanza steering wheel....fits....b13
Working on it !
b13 b14 p10 tranny fit each other
b15 p11 do so too
b13 m/t crossmember fits nx2000 m/t
all motor mounts and brackets are the same for b13 and nx2000 if same tranny type
shift linkage is the same b13 and nx2000
vehicle speed sensor on 93 and 94 b13 dont fit nx and b13 of 91 and 92
b13 ecu fits nx2000
ill post more as i go in my swap
edit:
o forgot to mention
a vq35 from a fwd will fit in a b13 engine bay iwht some custom motor mounts:biggthump
wants 2 dry hump chriscar
early mazda 626 lips fit -b13 sentras.
s13 "pig nose" lips fit -b13 sentras
G20 radiators fit -b13/b14 sentras/200sx/nx2000 with sr20
nx2000 duel core radiator fits - all B chassis cars with sr20
out with neck injury :-(
2000 Dodge Ram 1500 front lip fits B13 (w/ minor trimming)
I Keep It Unique
lol we need to organize this by category...
Suspension:
B13 struts will fit a NX and vice versa
B13 strut rear strut bars will fit a NX and vice versa
NX and B13 ball joints, lateral arms, ball joints tie rod ends sway bar endlinks, and bushings are all the same
NX1600 and all non SR20 powered B13 inner tie rod ends are not the same as the NX200 and B13 SE-Rs
N14 Cusco front strut tower bar will fit an NX, B13 or B14 and maybe even the P10?
P10 rear bearing knuckles and Altima front hubs (4 X 114.3) will fit a B13 or NX why would you want to do this? Just one way to do 300zx front calipers....
Maxima front hubs, Maxima rear bearing knuckle and remachined rear splines on a B13 or NX will enable a 5 lug conversion with 300zx front brakes and maxima rear brakes
240sx to 300zx conversion SS brake lines will fit a B13 and NX for the brake conversion
Maxima MC non abs or abs depending on your vehicle is also needed for the brake conversion
Maxima SS brake lines fit a B13 and NX
NX2000 rear disc brake setup will fit a B13 and vice versa
NX2000 or GTI-R front calipers fit a B13
P10,Maxima or GTI-R rear calipers fit a B13 or NX
GTI-R or Altima MC will fit a B13 or NX
Exterior:
All B13 trunk lids are interchangeable
VW golf headlights or projectors will fit a NX with some cutting of the NX
NX and B13 side markers are the same
Sunny or Tsuru front bumper, side skirts, rear bumper will fit a B13
Sunny headlights or Tsuru headlights will fit a B13
BMW 3 series headlights will fit a B13
GTI-R front bumper will fit a P10 and a B13 with some modifying
B14, B13 and NX rims are all interchangeable
Interior:
P10 electric trunk popper can be used on a B13 or NX with an aftermarket alarm
P10 Leather Ebrake handle will work on a B13 and NX
NX or GTI-R center console will work in a B13
LHD GTI-R dash will fit in a B13 or NX
B14 HVAC controls will fit in a B13 or NX with some cutting
B13, GTI-R and NX instrument clusters are all interchangeable with some wiring
GTI-R dash gauges will fit in a NX or B13 with some modifying and wiring
Every piece in the dash of a B13 and a NX are interchangeable
NX carpet and B13 carpets are the same
Tsuru floormats will fit in a B13
GTI-R, NX, P10, B13, Tsuru, S13, S14, Sunny, Maxima and Stanza steering wheels are all interchangeable
P10 and Maxima map lights will work in a B13 or NX
B13 4dr power window tracks, Power lock motors, B14 power window and lock switches with some wiring and some relays will enable you to have power windows and locks on the B13
GTI-R power folding mirrors will fit a B13 (Have to have the actual mirror (lens) from the B13 cut down and swapped out with the GTI-R ones or you cant see out of them something about the mirrors being concave or convex for rhd lhd viewing purposes) with some wiring
P10 and B13 GXE electric HVAC controls will work in a NX or B13 with some wiring
My latest mod coming up will be digital climate control using maxima parts and it will all work in a B13 or NX
Engine:
GTI-R/NX power steering coolant lines will fit a B13 (moves the cooler to the front of the car by the radiator
GTI-R, NX, P10, P11, Bluebird, Sunny, B13, B14,B15 etc... engines are all interchangeable
P10, P11, NX, B13, B14, B15 transmissions are all interchangeable
B13, NX GTI-R power steering canisters are interchangeable (I dunno I just like the round ones that come in the JDM cars vs the squared off ones on the american cars)
GTI-R intercooler setup will fit a B13 and the NX with some modifying
GTI-R, NX, G20 and B13 radiators are all interchangeable
GTI-R carbon canister (smaller for a cleaner engine bay look) will fit a B13, NX or G20
NX and B13 AC setups are the same
NX, P10, Altima and B13 brake boosters I believe are all the same
NX and B13 engine bay wiring harnesses are all interchangeable
NX and B13 fuel pumps are all interchangeable as well as the fuel level senders
NX, P10 and B13 automatic ecus can be used on a manual NX, P10 or B13 but not vice versa
NX downpipe and cat and the section between the cat and the muffler will fit a B13 and vice versa but the mufflers will not interchange
that is all for now...
Done.
Actually, what would be even better, is to do a parts interchangability list in Excel, and upload it to the first post so that everyone can download it. Just add a post with something that should be added.
(Something like a cross reference chart)
Discussion Starter #14
Retired for now...
for b14 1.6 swappers.
You can use your b14 1.6 harness, Not all things will work though.
You can use the b14 rear and tranny mount from a 1.6... recommended using 1.6 linkage with that as well...as mounting point for the 1.6 is slightly off which why all the people have a problem with linkage.
95-97 ga16de and sr20 engine bay interior harness is the same minus the stock alarm stuff.
b13 corner light bulb sockets fit b14
Stock u13 FMIC mounts nice in the front with little modification.
slave to the grind
brennan is a post whore and has way too much time on his hands...lol
tekkie has the righ idea it would make it much easier to use and follow
love the Florida sun!!
Don't ask me how but anyone with a RR engine can use a Honda filter ( except S2000, Insight ) , only if you use 15208-9E000.....And anyone with a Nissan that uses that same filter can also use stock OEM Kia and Hyundai oil filters ...... same thread design....
P/N 15208-9E000. any Kia/Hyundai and Honda oil filters ( except S2000, Insight ) are the same ...
HERE ARE SOME...
-ALL SR20DET PISTONS ARE THE SAME COMPRESSION.... GTI-R AND BLUEBIRD.
-GTI-R MAIN BLOTS CAN BE USED IN ALL SR20'S, THEY ARE STRONGER THAN THE REST.
- GTI-R RODS ARE THE STRONGEST FACTORY ROD, AND CAN BE ADAPTED TO ALL SR20 CRANKSHAFTS WITH USING THE GTI-R ROD BEARINGS.
-ALL FWD CRANKSHAFTS ARE THE SAME. THE GTI-R REQUIRES YOU THOUGH TO DRILL THE FLYWHEEL FOR USE OF THE LARGER FLYWHEEL BOLTS THAT THE GTI-R CRANKSHAFT RQUIRES.
-BLUEBIRD, GTI-R, SR20VE, SR16VE, AND SR20DET RWD USE THE SAME OIL SQUIRTERS.
-THE SR20VE, SR16VE AND 20V HEAD WILL FIT AN SR20DE OR SR20DET BLOCK.
-ALL TIMING CHAINS HAVE THE SAME DIMENSIONS EXCEPT FOR THE 20V SR20VE AND SR20VET.
-A S13 RWD SR20 HEAD GASKET WILL WORK ON A FWD SR20DE, OR BLUEBIRD.
-A 20V SR20VE FACTORY STEEL HEAD GASKET WILL WORK ON ANY FWD SR20DE, SR20VE, SR16VE, OR SR20DET BLUEBIRD. I DONT THINK THE GTI-R.
-ALL WATER PUMPS ARE INTERCHANGABLE, EXCEPT FOR THE GTI-R.
-B13 SR20DE HAVE LARGER CAMS THAN THE B14 SR20DE. THEY ARE INTERCHANGABLE.
-B14 SR20DE HAS REVISED LIFTERS.. WHICH ARE INTERCHANGABLE.
-SR20DE CRANK GIRDLE CAN BE USED IN A SR20VE OR SR16VE WITH USE OF THE SR20DE MAIN BOLTS.
-VE OIL PUMPS CAN BE USED ON SR20DE'S WITH USE OF THE VE OIL PUMP SPACER AND VE CRANK PULLEY.
-SR20VE AND ROLLER ROCKER SR20DE OIL FILTER MANIFOLD ARE THE SAME.
-SR20VE AND ROLLER ROCKER SR20DE USE THE SAME VALVECOVER.
-ALL FWD SR20'S USE THE SAME REAR MAIN SEAL.
-ALL FWD SR20'S USE THE SAME FRONT MAIN SEAL.
-ALL SR20 HEAD BOLTS EXCEPT THE GTI-R ARE THE SAME.
-98' AND UP SR20'S HAVE THE REVISED TIMING CHAIN RAIL AND GUARD, AND CAN BE USED ON THE OLDER SR20'S.
-ROLLER ROCKER SR20DE'S HAVE A MULTILAYER EXHAUST MANIFOLD GASKET AND CAN BE USED ON ALL SR20DE'S AND SR20DET'S.
-B13 AND B14 HEAD TEMP SENSOR AND GUAGE TEMP SENSOR ARE INTERCHANGABLE, WITH CHANGING THE PLUGS.
-SR20DE, SR20DET BLUBIRD, SR20VE AND SR16VE HAVE INTERCHANGABLE INJECTORS PHYSICALLY.
THATS ALL I HAVE ON THE TOP OF MY HEAD FOR NOW...
CORRECT ME IF IM WRONG ON ANYTHING.
1 - 20 of 64 Posts
