PPG dogbox $4000
Price is for dogbox set only (as on picture, or you can check PPG website page.asp?productid=59 for description)
Barely used -- i blow engine pretty soon, so its a steal deal for perfect shape transmission setup.
Also have whole set to install z32 transmission on sr20 (plate, 1-piece aluminium driveshaft, rear end) -- sold separatelly.
Contact me if you want assembled gearbox (z32 transmission case, bellhouse cut to fit sr20det engine via plate.).
Any questions welcome PHONE ONLY 224 (381) nine-nine-four-3 (text first pls).
Rated at 800 horsepower this set was primarily designed for drift and drag racing use. It has helical cut gears for quiet street operation, yet offers close ratio's and dog engagement for fast shifting with or without the use of the clutch. This set comes complete with billet selector forks. Billet mainshafts are available by request at an extra charge if required for your application. Used, abused and praised by many top drift racers the world over, this product has found its way into D1 teams from Japan to the USA.
Retains the stock overdrive 5th gear and synchromesh engagement on 5th.
Ratios: 2.621 / 1.637 / 1.240 / 1.000 / std
Horsepower Rating: 800 hp
