I am just about finished with installing a Place Racing CAI on my 98 200sx ser and I have run into a problem. I can't seem to get the air filter on. There just does not seem to be enough space! Just when I think it's on correctly and start tightening the clamp, the filter pops off of the pipe. What should I do? Is there a trick to this?
Discussion Starter · #2 ·
Thanks for the advice.
I ended up moving the battery and battery tray over towards the engine about an inch. This allowed the pipe to move where it needed to for the filter to fit on. The move also provided some clearance between the battery and the intake pipe so the intake pipe won't rub a hole into the battery.
i have a 94 low port and ran into the same problem. i re-cut the hole further towards the front. this made space behind the k&n. hope that helps!
