So..it'd be time for a gearbox oil change for my 1998 P11 Primera, it has a SR20de, the 131hp version - and I got some questions:
There's....two plugs where to fill from? The upper one has the plug being the speedometer pinion. This is seemingly recommended in the FSM to be the hole used for filling, but that pinion is in quite a tricky place..image:
Then there's one also called a filler plug, in the full diagram for the transmission case, but it isn't the draining plug right? Also where exactly is the draining plug located? Would be glad if someone provided some photos of the plug locations...I've looked at guides for replacing gearbox oil but they are all so old threads that the images have been removed.
So in summary, how do I go about changing gearbox oil to my P11 manual 'box? Lastly, 75W90 is the most suitable oil for cold climates right?
