expect the unexpected
so i got the car a couple months back and since i got it when i make the turns it takes a while till it actually does the turns. I don't know if its only a bushing or if i have to change the entire racking pinion which is a lot of work. Let me know if anyone knows???? :)
Sunny driver
mmm. sounds maybe the tie rods ends need replaced. so you turn the wheel and its not moving the wheels? mmm.. I would say put it up on stands or a lift and check it out from under it. its gott a be a loose joint somewhere with lots of play. tie rod ends usually are the issue. Moog joints are heavy duty and last long with greasible ends.
Chris 92 classic
Sunny driver
did you find anything out about the rack? CV joints can cause clicking and wierd movement in the steering wheel. just wondering
chris
