21 - 33 of 33 Posts
Discussion Starter #26
Did this ever get sorted out?
Chris
Hi Chris,
The car has been running fine with the high port for over a year. What did you want to know?
SR20 ENTHUSIAST
I just meant the vaccum line mystery in the pictures you posted.
We are actually doing a GA16DE to 95 Lowport SR20 swap next weekend hopefully (if all the parts are here)
Chris
Discussion Starter #28 (Edited)
All hoses were all related to the canister, so they were disabled by insterting screws of a slightly smaller diameter into the ends.
Leaving the hoses and using screws will last longer than vacuum caps since the caps are not very durable.
I'm almost done with my 94 classic lowport to jdm highport swap, and I was wandering is it the same as the b14 swap...and do I need a rseistor in that plug by the tranny? Also need to know about the vacuum hoses...the jdm didn't have egr system...but my lowport did...I've blocked of the header I have on my block, but the lowports egr system had about 4or 5 hoses ...I need a diagram or a picture if somebody has one.
Discussion Starter #30
You can cap off or plug most of the vacuum lines since the EGR is not needed on the JDM motor. I know you will need the resistor for 95+ ECU's, but I am not sure about the 94.
Never mind dont need the resistor...B13......$!*^..
21 - 33 of 33 Posts
