Since you have a 96, your sockets are 9004's right? They should plug right in. But if not, you could just use your current bulbs as wiring harnesses. Take the glass part of the bulbs apart and sodder a wire to each terminal. You can then just splice and crip the corresponding wires to the projector's wiring harness,and WALLAH! You're done and you didn't have to cut up your factory wiring.
