Whut?That Ain't No Hondah
Ok, I'm currently using a 91-93 wiring/engine harness, which does not have a plug for an electronic speedo sensor. Of coarse everyone will state the obvious of why are you trying to use an electronic speedo sensor when you can just get a mechanical gauge cluster and use that.... The problem is I have an NX1600, which came w/ the electronic gauges. This gauge cluster is setup for an electronic speed sensor. I have an NX2000 mechanical gauge cluster, but the plugs are totaly different between the two.
So my question is either:
A) Does anyone have a wiring diagram to wire from an NX1600 dash to a NX2000 dash
B) Does anyone know where I need to run the electronic speedo sensor wires to in order for my speedometer to function?
93 models have the electric speed sensor, so I don't see why you don't have the plug.
