How do you test to see if yours is good? I had my car running great then it just died out of no where didn't sputter just died...
I remember with my ignition in the on postition I could hear my fuel pump and sparks if I moved the distributor by hand if it was all the way loose it does not do this anymore. I get spark and I have fuel in my fuel lines......
I need help badly this is a high port engine
/// God Speed! ///
So you do or do not have spark? Did you try to remove a plug, push it up into the boot and let the tip of the plug rest against a grounding point on the engine to check for spark at the plugs?
Yes I have plenty of spark....what I'm asking is can your power resistor or something in the distributor go out and still have spark?
/// God Speed! ///
Nope If you have sparkAT THE SPARK PLUG then the ignition system is doing it's job. Next I would pull off the fuel line coming off of the fuel filter to see if you have fuel.
This is what you need to make a engine run.
Fuel,Fire,Air,Compression,Proper Timing
One of these is missing.
