Does anyone know will the CG camber plates fit on aftermarket springs other that CG coilover? If so, will the plates lower the car even more?
Thank you
as long as it is a 2.5" inside diameter spring it will work. and yes you can lower your car 3/4 of an inch more, or you can use that for travel.
Whisky Tango Foxtrot
<font face="Verdana, Arial" size="2">Originally posted by caterc:
Thank you
They will not fit everyday type lowering springs. It must be a coilover type suspension with 2.5" dia. springs.
