In the current SCC review of the JWT S3 cams it lists the price of the cams as $560. Does that sound right? And how much is it for the 95-97 JWT ECU? Also curious if it costs anything other than shipping to have your JWT ECU retuned if say you decide to add the NOS kit later, or you get the ECU before the cams and then get the cams and need the ECU retuned (if that's even necessary when adding JWT cams, not sure if it is).
Also have read lots on cam installs. Those of you who have the SCC article (if you don't have this months issue I suggest you pick it up!
) it outlines the cam install very well, except I need some help clarifying some things. I understand removing the valve cover, zip typing the chain to the sprockets, then there's that wood wedge thing. In that picture on page 252, is he just showing kinda where the wedge would go but not have it inserted, or is that picture with it inserted/stuck in where it should be? Can't find the wood block stuck anywhere in subsequent pictures so it would seem it's stuck down there somewhere below the cam sprocket area. Next step seems to be to remove the cam sprocket bolts as shown in the second picture on page 252. Then you remove the bearing caps. Do the oil supply lines come out before you remove the bearing caps or after? Then there's the whole thrust bearing thing that tries to jam itself cuz of the valve springs. Maybe I should just get an FSM and that will explain the whole thing? I REALLY want to have a good understand of how to do a cam swap. I want to be able to do it in my head before I ever even think about getting JWT S3 cams cuz it's going to be ME doing with no one to help since there's no SE-R folks I know of in the area. Does the FSM do a great job of telling you all you need to know for a cam swap?
