1 - 2 of 2 Posts
Insane
Hi there,
Tried searching for this info and didn't have much luck. What bits are required to +t a sr20de? So far I've worked out I need a manifold+turbo, oil return and oil feed, injectors, IC+piping, fuel pump or is sufficient enough to handle 8psi? and ecu.
The car I'm doing this on is a u13 attesa bluebird "will upload some photos when we get some decent weather here in NZ" engine numbers are 78e 1r. Had a browse through the compression head n block code thread n didnt find any info on my engine, according to the list 78e is a sr20det but I dont have a hole for oil return or red rocker cover.
Thanks in advance.
Hybrid Power...
You MIGHT need an AFM that matches the ECU that you run it off. Not 100% sure about this though.
1 - 2 of 2 Posts
