Hand Fed SR20VE
I did my second swap on a my p10 g20 I was wondering on the tps.. Am I suppose to use the g20 one or the ve one.. Because the tps connector of my harness is diffrent and when I did my swap on my b14 I used the ve tps..... lmk thanks
Do you have a high port or low port G20? What throttle body are you using?
Hand Fed SR20VE
I think a high port.( injectors on top & intake underneath..) I always get mixed up......I am using the ve throttle body....should I use the g20 one?
Hand Fed SR20VE
say im lost i searched and it said to use the ve tps and my harness was two plugs does any one know which wires to splice it would be a big help thanks
Hand Fed SR20VE
i was reading a nissan performance mag...ve install on a p10 and they changed the throttle body....that right.,,,?
