1 - 2 of 2 Posts
Banned
Well, its seems I finally solved my weird, lift off throttle problem, at first I though it was my ball joints which there were bad to then I thought it was my Tie rod ends which they weren;t in the greatest of shape neither but that still didn;t fix my wierd lift off throttle torque steer problem after I replaced them, so today I lift the car up again and I see my passenger side R&P bushing squeezing out of place so I fix that side which is doable with the engine in the car, and what do you know half the problem goes away, so I take a look at the driver side R&P bushing and its also on its way out to, but that ones gonna have to wait until I can remove the tranny cuzz u cant get at that one for ****.
My symptons where when I lifted off the throttle my car would sway like this
"a quick, right-left-right". Almost like a sea sickening sway you'd get on a boat.....lol
Learn to swim
Lucky you. I have to go pick mine up in the morning from its rack and pinion transplant...Josh
1 - 2 of 2 Posts
