It will not be 11:1 in a GTIR. The GTIR has a different cylinder head CC, therefor it will be less than 11:1. I dont know what Z32's will make it. somewhere between 10.5 and 10.8:1 id guess.
Remember that the GTi-R combustion chamber holds more volume than the other DE's, DET's. Because of this regular caluclations will be about 0.2 points off. For instance the 300zx pistons will only give a 10.8:1 CR (from my calculations)
With the 1.2mm head gasket your compression ratio should be 8.4:1 CR. If you get a Tomei 1mm head gasket and the 300zx pistons that should net you an 11.1:1 CR. You could always get some
Wiseco makes some 11:1 CR pistons for the DE. This would yeild a 10.9:1 CR in the GTi-R motor. With the Tomei 1mm head gasket you would get 11.2:1
Not worth it for that extra 0.1 points but the option is out there to use forged DE pistons, they will need to be machined to clear the oil squirters.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
SR20 Forum
