1 - 12 of 12 Posts
WWJD
The oil pump could be going bad, worst case, check oil pressure soon!!!!!
Banned
yes..i had this problem for a month or so after installing my JDM motor....then the motor locked up....check oil pressure and my advice would be to get ready to order up a new motor.....
"The world is yours"
ive got a few nickel sized dents in my oil pan. is that something to worry about? been there at least 2 months and have not seen any problems.
Whut?That Ain't No Hondah
I'd play it safe. Once you pull off your oil pan you'll see that even a slight upward dent under the pickup tube will cause sever oil starvation.... Pull out the pan and beat it w/ a piece of wood and a hammer where it rests under the pickup.
Oil Starvation == Death to your motor. I'd take it pretty seriously.
1 - 12 of 12 Posts
