1 - 2 of 2 Posts
aite so i've pulled off my intake and resonator (do i need to kepp it or do you guys know of a way i can just plug that hole?) and i see 2 bolts sitting just below the main intake runner (is that called the plenum?(the dealie that runs paralell to the engine)) are the 2 bolts the ones that hols on the starter?
Revolutionary
there should be two bolts diagonal from one another, on the transmission they should be 14mm- metric, or 9/16- standard, all the other bolts on the transmission near these bolts will be bigger.
1 - 2 of 2 Posts
