Wondering only.
Rebuilding GTiR T28
should i change to Trim 62 wheel or Super 60 wheel
and slap a S14 T04B compressor housing on it ?
or keep as stock ?
what the expected out put i can get from Trim 62 wheel
or Super 60 wheel.
Thanks..
just wondering only worth to spend the extra for the wheel only
as well the 360 trust bearing
i wouldn't go with a super 60 T3 wheel cause its smaller than the stock GTiR wheel. super 60 = 33lbs/min, GTiR = 35lbs/min. I had a GTiR rebuilt and they guy showed me the difference. The GTiR wheel is more aggressive than a super 60. If you go bigger you may get into mis match problems with the comp/ turbine sizes. don't get too greedy with the comp and forget the turbine side.
<>< Jesus is the Answer
so with the t04b compressor housing, is that a direct swap? I have to rebuild the turbo I have before I throw it on the car and while im rebuilding i might upgrade if its worth doing. yes? no?
