Is Redline 75W90 GL5+ Gear Oil Safe to use in an SR20 M/T?
  • Hell yea, that stuff cost you $11 a bottle!
    Votes: 1 25.0%
  • **** no, $44 or a new tranny, what's better?
    Votes: 3 75.0%
1 - 15 of 15 Posts
With the revival of the Redline thread, I wanted to know what you guys think about the oil I just put in my tranny...
This stuff is exactly like MT-90 except for the GL5 rating... I went to the only store in the city that carries redline stuff, and this was the closest thing to MT90 I could get... Should I change it or do you think I am OK? Still shifts pretty good.
Undecided
Not sure. I'm wondering along the same line. I bought Lucas 75w90 Synthetic thats desgined for High performance and LSD equipped trannys. It says its a replacement for GL5 and GL6.
P10 Geek
The 75W90 is not safe on the Nissan synchros. It will shorten their life span drastically. MT-90 is specially formulated for GL-4 applications like the Nissan synchros.
IMO you should get the correct type and drain your tranny.
The Super Mechanic
What makes nissan syncros so special. They are made of brass
I'm gonna call Courtesy, Mossy, and Redline tommorow and see what they say... I kinda don't wanna change the fluid again, but I guess I might have to. Maybe I could just refil the old oil bottles and try to return it :rolleyes:
Pâté Performance...
It "eats" the brass. Not a good thing.
woo dee woo
I just did some serious research and i had no idea that our transmissions could suffer damage from a GL-5 oil. When i had to replace my driveaxles back in september i topped off the tranny with some valvoline synthetic 75-90w i had laying around (which is GL-5). i just ordered some redline mt-90 and i will change it out as soon as i recieve it. on the redline site it says that GL-5 will reduce syncro life by half...no good. I wonder how much damage i did by topping off the tranny with GL-5 after the driveaxle swap. It's only been about 6 months.....but i beat on my car pretty bad.
Now accepting donations!!
I thought mt-90 was 75w90...? :confused: It's just that it's GL-4, not 5.
Discussion Starter · #12 · (Edited)
The guy I talked to at Redline said the same thing that the guy reported on the Redline thread. Bottom line, although the GL5 75W90 doesn't eat Nissan synchros, it does have a friction agent in it that makes shifting harder. I know now to always go with MT-90!
Gonna go across the Golden Gate Bridge to get some MT-90 now.... Some times i don't know whether this forum is a curse or a blessing :redface:
jk, thanks for the input. :D
damn mackenzie...
P10 Geek
I was not referring to MT90. He (ResidentWarui) stated he used 75W90 Redline Gear Oil. There is a difference.
Sorry I did not clarify which Redline 75W90 I was referring to. :rolleyes:
Here:
THIS ONE IS BAD FOR NISSAN SYNCHROS (hard shifts, etc.)
75W90 Gear Oil - the preferred product in nearly all car and light truck differentials, both conventional and limited-slip. 75W90 is preferred for most racing applications. It contains friction modifier which is recommended for limited-slip units. 75W90 Gear Oil can be used in many transmissions and transaxles; however, other Red Line lubricants have better frictional properties for rapid synchronization. Exceeds API GL-5.
THIS IS THE CORRECT 75W90 TO USE
MT 90 - Manual Transmission/Transaxle Lubricant. A 75W90 GL-4 gear oil which is designed for manual transmissions which require 75W90, or 90 GL-4 gear oils or motor oils. Uses the same chemistry as MTL , but is a 90 WT in order to satisfy certain manufacturers which recommend SAE 90 GL-4 gear oils.
Discussion Starter · #15 ·
Just put the MT-90 in... MUCH BETTER! Shifts into first easier than ever.
Oh yea, and for those of you who made the same mistake I did, don't try to save the old 75W90... In my case I had the GL5 stuff in for about 200 miles and figured I could re-bottle and sell it to some cheap guy for $5/ bottle. Anyways to make a long story short it ended in a huge disaster, big pool of tranny fluid on the floor.... Kinda hard to do this alone without a clean pan that will catch a lot of oil. That fluid really comes rushing out. Glad I didn't try this at home...
1 - 15 of 15 Posts
