Just need to make sure. nothing when I searched.
In my Haynes manual for b14's it says to unscrew the screw on the distributor rotor to replace. Ummm, there is no screw.
I tried tuggin' it out, but doesn't budge too easily, just want to make sure that you remove it buy just pulling it off... I don't want to break anything if this is not the case.
EDIT, NVM, if you pull at it hard enough it comes off.
