I am assuming all the mounting points on the car are the same, can I do this?
I can pick up stock exhaust for a song, the full thing, which is what I need, manifold to the muffler. As long as the 98 stuff is consistent will this fit on the 97 car (longer cat is mated with the shorter bipe). This should be simple yes, no answer, I hope and believe the answer is yes.
The rear O2 sensor is different. The thread size is different, as is the harness.
The signal is the same though right? As long as I use the 98 o2 sensor, solder the O2 sensor in it will work?
