RNN14 GTI-R 1994 Complete Rnn14 GtiR sr20det motor swap f/s (complete for a SR20de motor car Se~R.) motor is complete with original attached harness, ecu, mfs & mfs intake hose, distributor with spk pg wires and with ignition coil, 4-throttle body complete intake. after mkt injectors,alternator, starter, flywheel and clutch and flex plate, T-28 turbo in great condition, Compression on the motor is 170psi, Compression,leak tested and Dyno bech tested the motor has been fired and tested so no noise or smoke from the motor also comes with a limited start up warranty. Price is $1995
Shipping - buyer pays for shipping
So.Cal buyers can pick up and check out the motor.
photos can be sent out
