So, in the latter part of the V8 thread, we have started discussing the aerodynamics of the S-chassis.
Having followed the radiator test conducted by fellow 240 owners/enthusiasts on FA, it was proven that running the upper radiator panel and some sort of underpanel to direct air through the FMIC and into the radiator (instead of below or above the radiator) proved to work very well in lowering water temp. Makes sense.
From that alone, it should be evident that proper ducting of air can aid in the car's performance.
It is also evident that aerodynamics on any car can improve its performance, whether it be cooling or reducing drag/increasing downforce.
I started this thread because I am planning on creating an undertray that will work both as a lower radiator panel and a sort of a front diffuser. It will start from underneath the FMIC core, and extend to the engine crossmember.
However, from the articles linked to in the V8 thread suggests, there are many shapes/forms/angles/etc. to consider when dealing with aerodynamics, as anything, however minute, can cause a huge difference in the outcome.
I do not own one of those pressure gauges, so if someone on here has one, I wonder if you guys might want to be a guinea pig? haha
Basically, let's all enjoy a discussion of ideas for an undertray that would help in cooling and create downforce on the front of our cars.
