hydrocarbons.........sounds like the cat isn't burning that stuff completely off.
I don't think that you can prove a cause > effect relationship between the cams and passing emissions unless you did back to back emissions tests between the stock cams and the S4's.REDSENTRASE-L said:good tip! i dropped the car off and it took em about an hour before they started. so i am absolutely sure it's the cams. maybe i should retard the timing ti help reduce emmisions. i dunno.
OmegaManEX said:i thought you also failed if the timing wasnt at the stock setting ? ..or.. is it only if its advanced?
thats what i thought .. but dont take my word for it.MARCUSMARC said:Do they check it?
They do check it, its pretty methodical...OmegaManEX said:thats what i thought .. but dont take my word for it.
they most definitely do. my posts on this subject before are still aplicable.James said:They do check it, its pretty methodical...
