1 - 8 of 8 Posts
Drive it like ya stole it
The diameter of the rotor would give you an answer.
I misread the post, yeh the 100nx came with the larger pads I think. It they say "for ABS" then yup, they're most likely larger.
www.FAIRTAX.org
The Euro NXs have the same rear brakes as the G20 and 89-94 Max SE. They are larger than the US NX and the SE-R.
newbie
$1,000,000 question though..what master cylinder are they using? If it is the factory NX2000 spec M/C then I will swap to bigger brakes w/o worrying about bias.
I'd say as long as you're not swapping out the front brakes, it'll be fine Ian. NX$paniard put an altima SE master cylinder on one of his NXs because he had the BABK on front and maxima calipers on back.
1 - 8 of 8 Posts
