Running a Airresearch T3 with a stainless manifold... Mr gasket copper gasket but it still leaks didn't leak on my T25 a reputable shop told me to put some silicone on it but thats sounds kinda sketchy... also the downpipe leaks connecting to the Jpipe. 3 bolt flange. any suggestions on a good solid gasket that might help my problem. I also think that the exhaust manifold bolts keep backing off but not exactly sure if a lock washer would help and its obviously to hot for a nylon thread nut. Anyone else run across the same kind of problem. I am pretty sure that the log manifold is warped but I tried sanding it flush with a grinder at work to no avail
