<font face="Verdana, Arial" size="2">Originally posted by Mike sr20de:
has anybody heard of this? when put my car into gear the shifter still moves around like it is in nutral...
I can still shift, but I have to find the gears by memory. there seems to be no guide for the stick.?.
any help would be appreciated.</font>
A little bit of movement is normal. Anything obviously excessive would probably mean you have something wrong. I would suspect the shifter bushing and/or linkage.
Jack up the car and verify everything is tight and snug under there. If the bushing is abnormally soft or worn, get the ES shifter bushing, it's only like $8.
Jordan (Stormy)
Black 1998 Sentra SE w/ HS CAI, HS G3 Header, Custom 2.25" Exhaust, JWT S4 Cams, UR Pulleys (NI), KYB AGX's, Eibach Sportlines, Courtesy STB's, ES Mounts, ES control arm bushings & shifter bushing (NI), PWST X-Drilled Rotors w/ Axxis MM Pads, 205/50 Pirelli's, Nis-Knacks goodies
