Take the heat sheild off the cat, and the one above the cat. You'll see 2 bolts on the bottom of the car, toward the back. Take those off. Now look at the shifter, and take the one off the shifter itself, and the 2 that hold the shifter to the support rod. It's much easier to get to these, if you remove 2 bolts on the same side of the cat( left of right, not front or back), and loosen the other 2. This gets the cat of out the way.
Eric Waterman
1996 200SX SE-R
1997 200SX SE-R
1991 Sentra SE-R
