<font face="Verdana, Arial" size="2">Originally posted by LowDownNX:
1BAD_NX: What setting do you reccomend, and i have never installed a short throw shifter, do you have any advice, does it come with instructions or how to install? Thanks alot!</font>
I hope its not too late LowDownNX, I was away from my computer for a while. Anywayz, this was my first major mod on my Nx, and finished it without any problems.
Yes there is a real good manual that comes with the Pacesetter. Basically
1-jack up the car(secure it),
2-loosen the exhause hanger near the heat shield(also take off the ground wire),
3-get the heat shield out, the shifter will be exposed now.
4-remove the shifter spring and start unbolting the shifter mechanism
5-the shifter housing must also be removed here, (there's an M10? bolt on the shifter that you must remove also)Note: after you remove the nut use a hammer or something to pull out the bolt(I wasted a lot of time trying to unsrew it out, duh!!)
6-(hopefully you've already removed the knob at the begining) and now get back into the the car and pull out the shifter and put the new shifter on (use the lubrication provided)
NOTE: (if you want a real quick shift like I did, put your shift ball to the very top of the thread and tighten the set screw. It will also be necessary to cut the heat shield (or just hammer it for clearance like I did)
Putting things back will be a very easy task if you jus reverse the steps (or jus use your imagination like I did
***These are just the important steps I remember from my last year's install and should only be used as a guide. (the Pacesetter guide will have a more complete procedure on the install.
Good luck, and enjoy the ride
Nick
