<font face="Verdana, Arial" size="2">Originally posted by Sr20 B12:
Does the rim size make a difference? Also how friendly is the 24.5x8x?? slicks on the transmission and on the wallet?
Most drag wheels will be between 13x7.5 - 13x8.5 . You will size slicks according to estimated power. The 22x8x13 M&H slicks have held 350 hp. Anything past 350hp and you should go with the larger 24.5x8x13 MT or 24.5x8.5x13 M&H Slicks. My tranny is cryo treated and welded, I have an ACT 6 puck w/ Xtreme P/PL, and I launch the car @ 6000 rpm's at the track. It has held up fine so far (knock on wood!), but there is always the possibility of grenading the tranny. Remember, the larger the slick, the lower the mph will be. My 118 mph on slicks would be like 121-123 mph range on street tires or with smaller slicks like the 22x8x13's.
Louis Anaya 1992 Sentra SE-R
349.6 hp & 301.4 ft/lb @ 19 psi, 13.6 @ 111 mph(Street Tires),12.0 @ 118.77 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (7-9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Sumitomo 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24.5x8x13 Slicks(Drag)
