Ok, I just got my '93 SE-R(TB below injectors)-high port I guess?
OK, now I really wanna go turbo. I have been reading up on the F-MAX kit and HS kit.
questions. I only want a stage one. 12psi highest boost I'll go. I know after 10psi I have to upgrade fuel pump and some other things, right?
Ok, now a clutch is mandetory. Will this eat up my tranny. I do not plan on being overly hard on it, just when the time calls.
So will the tranny hold up with the "light" boost levels(around 7-8psi)?????
And what kind of times would I run on on that boost with the F-MAX kit. Does the boost stay strong to redline or does it have that reverse effect where it actually slows you down at a certain rpm???
Last question for now. The F-MAX site says it is in development...but it is out now right? you can order them???
Thanks a lot, shea.
Thanks a lot, shea.
