I no longer have the stock engine wiring harness there fore the speedo and tach will no longer work unless they are rewired.
Speedo Problem
There are 2 wires coming from the speed sensor. And there are 3 or 4 inputs for the speedo....
Tach problem
There is a brown wire on the TEC3 that is for the Tach signal and again the stock tach has 2 or 3 inputs.
For each of the above i know one must be a ground (the number 23 in the first diagram)
Here are the pinouts and wiring diagram for the cluster.
Can anyone shed some light on this for me? If not i guess my next question would be has anyone ever wired up an Autometer electric speedometer? And do you know what resistance values our fuel level sender uses?
Speedo Problem
Tach problem
