Just this last weekend I found out that part of the brake caliper mount is scraping off a bit of the inside of one of my aluminum wheels on my '91 sentra. These are the stock brakes, and I've never had a clearance issue before.
The relatively thin piece that connects the top and the bottom part of the brake caliper bracket (the one that arcs around the lugnuts and rotor), is sticking outward on the top more than the bottom of it is, and I can't figure out what is bent to make it do this.
Also, the brake pads are also very unevenly warn (the cause of this problem or the result?
I haven't hit any big pot holes or anything like that, and the wheel bearings seem fine.
There is very little clearance in this area to begin with, but I haven't had any problems in the past. I know this would probably be easier to explain if I had a picture.
Anyway, does anyone have any idea what could have caused this to happen? I need to replace the front pads, but I want to get this fixed before I do.
Thanks,
Aaron
Thanks,
Aaron
