Get Some!!
What's the best plug to use with NOS?
I know that you'll run through them quicker so what's the best bang for buck for the shortened life?
Get Some!!
Discussion Starter · #2 ·
back to the top.
Get Some!!
anyone?.... anyone?.... anyone?....
What is your jet? Lets say 60.... you need to drop a heat rang. Stick with NGKs, nothing else works well on SR20DEs. If your doing Platinums try a PFR6B-11 and a BKR7E for standard normal ones. The factory may have changd the name a bit but not the heat range number. You may have to keep the gap within the low factory specs (32-35 factory rang) because of the higher compression. Otherwise you might start missing with a big gap. Going through plugs is fun, but if you do not drop your heat range you made start eating tips off the plug (as 2 of my 75 jetted friends did) and if that gets stuck in a valve.... Fun rebuild. Do you have a Fuel pressure controler?
gap to a .28 and run a heat range 6 with a 50-75 shot. nissan part # 22401-20j06 is the 6 non platinum. use these b/c they are cheap and you will go through alot of them tuning, running, ect.
98 se-r w/ p/r cai,jwt s3 cams, stillen header, courtesy exhaust, ur pullies, JUN flywheel, ACT clutch, eibach springs, kyb struts, st sways, cusco camber plates, f/r strut braces,stillen lower control arm brace, lotsa bushings, and a bunch of other crap
I ran the BKR7E Non Platinum NGK Plugs with much success. These are pregapped to .032" . Gappe dthem between .028" - .030". You should be fine with these especilly with the summer coming!
Louis Anaya 1992 Sentra SE-R
349.6 hp & 288.9 ft/lb @ 19 psi, 13.6 @ 111 mph(Street Tires),12.0 @ 118.77 mph(Slicks), Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (7-9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Sumitomo 205/40/ZR17 Tires (Street), 13x7.5 White Lenso VPD's w/ Mickey Thompson 24x8x13 Slicks(Drag)
