The SR20DE successor that is supposedly going to power the '02 SE-R. In the US it'll be a QR25DE, but the specs should be very close.
Displacement: 2488cc
Compression ratio: 10.5:1
Bore x Stroke: 89mm x 100mm
Max Power: 178hp @ 6000rpm
Max Torque: 192ft-lbs @ 4500rpm
dyno chart of the new motor:
Looks to be VERY promising. The torque curve isn't terribly flat, but SR20DE like since has a small bulge at 4200rpm or so. Jay Hassinger mentioned
"I'm really trying to stay positive about this motor but this is a stroker
motor. ACK!
The KA is a stroker motor and while I like it, strokers get unsettled at
high RPM and don't usually make high RPM hp. By comparison the SR20 is
square. (Bore and stroke the same) that's why it's got a ton of mid-range
and still like to rev. The Honda (And new Toyota 1.8) motors are very
undersquare. That's why they like high rpm, high gas flow velocity and make
little torque.
I really hope Nissan works some magic into this engine so it's not another
"KA" type motor. The SE-R needs a screamer, leave the strokers for the
Frontier;."
motor. ACK!
little torque.
Frontier;."
