Mine came out when swapping the transmission in my nx2000. Do I need to remove the dash, or can I just remove the cluster and hook the speedometer cable back up? Thank you ahead of time.
what way do you route your hand? what do you have to go around, can you just go over the top of the cluster or to the side...?Well,l the way most people would do it is take out the cluster, connect the speedo cable, push the cluster back in the dash, then screw the other end into the tranny.
Remember, if you already screwed it into the tranny, there won't be enough slack on the cable to put it into the cluster when you take it out.
Personally, I've always just stuck my hand behind the dash and was able to connect it that way.
Probably the side. To get your hand over the top or the bottom you would have to pull the cluster all the way out and probably would have enough slack to do it. To get to the back of the cluster with your hand through the side just unbolt it. Grab whatever side you want to go through and then reach back there.what way do you route your hand? what do you have to go around, can you just go over the top of the cluster or to the side...?
:eek2: But the octuple is just a myth in the ancient man whore tales. Never in my life did I think it could be realSerban is also very skilled with unhooking a octuple (8) hooked bra with one hand.![]()
