motorslammed200 said:
tranny
motor mounts(You need three mounts ,tranny , otherside and the rear mount.you
need the front and rear brackets for the mounts. )
ecu
wiring harness
axles
MAF
header downpipe
radiator hoses (Se-r radi)
A/C compressor(if you keep it)
Power steering hoses off (non abs sr20 powered car)
Alternator /( power steering pump) you might can use old one
shifter stabilizer bar
clutch flywheel clutch cable
Starter,se-r axles, axle bracket 02senser
you can send the check to LOl
