the 914 is RWD right? i dont think a BB det would work than. Go for the red top (if it fits, i have no idea) and get ready to spend a lot of money and time on fabrication and parts.
Yes, this is why i was asking where engine is. There was a car in ether SCC or turbo mag (forget which one) , a porshe with a 4g63 mounted in the rear. If the set up is the same, than u can use a transversley mounted det (thus the BB motor)91DE+T said:The 944 is a traditional front engine rear drive car, the 914 on the other hand is a mid engine rear drive configuration. I think there would be too many issues with the tranny to make it work. Maybe a MR2 turbo engine and tranny would be a slightly easier swap.
why use a rwd sr? i've been searching the internet, and as far as i can tell, the 914's engine is a horizontally opposed 4 cyliner (in most cases), mounted transversely. so a fwd sr would work best, though the v8 swaps ive seen are longitudinally mounted.TheRiotHero said:you need a RWD SR. if youre going to do something like that i wouldnt be thining of the cheapest way to do it (seriously)
The radiator goes in the front, like in a new 996, or most any other water cooled rear engine car, i would think. but it would take some skill indeed.Stirpicult said:why use a rwd sr? i've been searching the internet, and as far as i can tell, the 914's engine is a horizontally opposed 4 cyliner (in most cases), mounted transversely. so a fwd sr would work best, though the v8 swaps ive seen are longitudinally mounted.
the problems are going to occur with where to mount the intercooler and radiator. the intercooler, if using a fwd bb det, could most likely stay on top if you fashioned up some trd/mr2 rice scoop thing. the radiator would be harder. that would take some skill.
thats what i figured. but the routing of everything is going to be a monster.Mikeb23ft said:The radiator goes in the front, like in a new 996, or most any other water cooled rear engine car, i would think. but it would take some skill indeed.
