What kind of SR20DET Intake Manifold is it? Bluebird DET, GTiR DET, or RWD Silvia DET? The Bluebird DET has the exact same intake manifold as the 91-93 Sentra SE-R other than an additional vacuum nipple. The GTiR w/ quad throttle bodies will fit onto any of the US SPEC SR20DE's, but I have no clue how you would benefit from this. I do not believe the RWD Silvia Intake manifold will fit on any of the US Spec FWD SR20DE's. What car do you have?
Louis Anaya 1992 Sentra SE-R
13.6 @ 111 mph, Bluebird SR20DET w/ GTiR Pistons,T3/T04E,Deltagate Wastegate (9 PSI) FMAX Manifold, RevHard FMIC, JWT S3 Cams, JWT Ported & Polished Head, 1996 200SX SE-R Welded & Cyro Treated Tranny, ACT Xtreme P/PL & 6 Puck Disc, Cobra MAF, JWT ECU w/ 4 Bar Fuel Program, MSD 50lb/hr Injectors, JWT Fuel Rail, 300ZXTT Fuel Pump, AeroMotive Adjustable Fuel Pressure Regulator, Greddy Type "R" BOV, Greddy Profec B, Greddy Boost & EGT Guages, UR 4 Pulley Kit, Powerslot Rotors, Axxis MM Brake Pads, ES Motor Mounts, Topspeed Short Shifter, Momo Cobra Shift Knob, KYB AGX Struts, GC Coilovers (350F/600R)& 17x7 White Tenzo Shu-4's w/ Kuhmo 205/40/ZR17 Tires
