CyberIce
·Guest
I would like to knwo the 1/4 miles and 0-60 time for a nx2000 with only a bb sr20det and JWT cpu!
thanks!!!
stock Nx2000 1992
thanks!!!
stock Nx2000 1992
I don't think you are going to get very many responses on this topic due to it being so general and there being so many variations of results from person to person. It is very hard to say if you put an SR20DET into your NX2000, that it will run (X) ET @ (X) MPH; you won't get that from this list! What I can tell you is that you can most likely expect to be right at 200 whp @ 7 psi , IF, the car is properly tuned and running the way it should be. If that was the case, then you SHOULD be able to pull off mid-low 14 second passes on street tires with a decent 60' time (2.0-2.2) and you SHOULD be able to run mid-high 13 second passes on slicks with a good 60' time (1.7-1.9). This will vary from driver to driver and from car to car! You can't just throw on a turbo or do an SR20DET swap and automatically be able to pull off a 13 second pass! Racing is just like anything else; it requires practice!<font face="Verdana, Arial" size="2">Originally posted by CyberIce:
thanks!!!
