SR20 B12,
Is using his stock DE maf or is he running the GTI-R DET maf with the GTI-R DET ECU? I know the stock DE maf tops out at around 8-12psi or 220hp depending on who you talk to. If he is running that boost with the stock maf He could be running into some trouble, or mabey he found a way around it?
Slownx2k,
From what I have heard the DET ecu cant read the signal from the DE maf. I'm using the JWT ecu set-up in my car with the stock maf.
Mike
