1 - 2 of 2 Posts
Messed with the pins in the ecu, and everything started getting power, got it to start, we had to redo the timing, tried cranking it again, and nothing has power again! please help
SR20DET
does the car turn over? did you do a auto to 5speed swap? is it a s13 or s14 240sx? blacktop or redtop am assuming the car does not turn over at all start with the little stuff check the battery,starter,fuses,fuel pump and cam angle sensor if your not getting any power to any of that you can start at the ecu checking the pin outs to make sure you are getting power to the ecu if you are start checking to see if you are getting power out of the ecu if you do have power in and out of the ecu start going through engine harness and check all the wiring and grounds let us know how it gos
1 - 2 of 2 Posts
