sr20ve 20v
4K views 3 replies 3 participants last post by  sss4me
#1 ·
Hi I have a sr20ve 20v engine . I'm looking for the wire diagram for that engine? I want to wire a Haltech elite 1500 to it.
#3 ·
options are depending on what your going to put the engine into. you could use the haltech patch harness for the silvia, rewired to suit the wiring harness on your current car (not hard). you could use a terminated harness and wire that up to all the sensors/injectors that the motor uses (alot harder). add the inputs for your vvl switch, and charge the dwb throttle body for a cable throttle , or use the p12 pedal in your car. i have a mate who has just done this in his n14 racecar
